How to use midi with split instruments
I had a very confusing experience with using Bitwig and split midi with Moog One.
I had base on the lower part of the synth and a pad on the right.
When I started Bitwig it would suddenly ignore the lower and higher limits of the keyboard and would play the base all over the keys (also high up where the pads go) and also the pads in the lower base area.
I changed the Midi send and receive so that each synth would be on 1,2,3 midi channel and that seemed to fix it. But it confuses me why that even worked.
Anyone knows how to best deal with it? I just want the instrument to behave the same way if triggered from Bitwig as if I play it manually. Any best practices?
Andreas
