how to trigger envelopes with guitar?
Hi!
I’ve been experimenting with the moog to amplify my guitar, but I’d like to be able to make the filter respond to the amplitude of the signal in a way that the envelopes get triggered whenever a note is played.
Now is there anything, some sort of noise gate I believe that has a CV gate output?
I think I can take the signal out of the insert and use it to feed such device.
Is this possible?
Something like this would do the trick…
http://www.blacet.com/IO.html
I have one and when I run a guitat into the EXT In on my Voyager(filter) I can get all sorts of cool effects. It does take you into the world of modular synths too.
Maybe the Moogerfooger MF-101 too?
The Moogerfooger filter pedal will give you envelope CV out, I believe. The Sherman Filterbank definitely will.
I was lucky enough to stumble upon a Filterbank, and I use it as a CV generator all the time.
-Hoax
thanks guys!
So can the MF-101 envelope be triggered by a determined signal level? (threshold)
and isn’t there any other cheaper option?
:blush:
