how to sync midi in Ableton with Slim Phatty?
I’m trying to send midi notes from an Ableton track to play the Slim Phatty - I have the midi track, just dont know how to send it to the phatty - any suggestions?
Am also trying to sync the midi clock from Ableton’s project tempo to control the SP’s LFO/Arpeggiator - is there an easy way to do this!?
THANKS!
Are you using USB to connect your Phatty?
If so, in Ableton’s Preferences select the MIDI tab and set the Phatty input as ON-off-off and the output to the Phatty as ON-ON-off. Then Ableton can Phatty record knob tweaks from the Phatty and send MIDI notes and clock to the Phatty.
To route MIDI tracks to the SlimP, in the I/O section of the track click on MIDI Output To and choose the Phatty in the menu and set the right MIDI channel (1 is OK since only the Phatty is on that USB connnection).
That’s it.
