HOW TO SETUP ANIMOOG - SUB PHATTY TO IMAC
Can somebody explain how to link animoog to my sp to my imac. I’m running animoog on a ipad air so it is a lightning connector instead of the usual apple charger input (same as iPhone 5). Another question I have is can the two merge to make one sound to use within my DAW (studio one). Or will I just be able to control animoog with the sp and vice versa? Would be very interesting if it was possible to have animoog as a 3rd oscillator over the top of the two from sp then have that sound as one wav in a daw. Thanks in advance for any help :slight_smile:
they are completely two separate things..
If you would have an IconnectMIDI-2 or something similar you can use the midi out from the SubP. to trigger Animoog (or vice-versa)
Then if you would have a (analog) mixer you could send the mix of those two to the input of your DAW. However, this seems overly complex and I don’t think this is what you want. Better to record them separate and and mix in the box.
Ok that makes sense. I watched a video on youtube a while back and this guy had his ipad wired to his lp via an irig or camera kit. But he was under the impression (or I misunderstood) that the two linked together could merge and play as one 3 oscillator synth, I couldn’t see how It was possible myself. Thanks for the help and clearing that up :slight_smile:
Actually, you could feed the audio from the iOS device into the “Audio In” of the Sub.
The signal would be in mono, but it would still work…
