Hi!
I’ve been starting to use the sequencer for advanced modulations, but I miss the ability to setup the Gate time for each step, as for the notes.
For exemple, I play (manually, not using the sequencer) a lush pad with ladder filter almost closed, and over it I would like to apply a 6 steps long sequence modulating the ladder filter, with different filter values at each step.
So far I cannot make it sound as when I do that modulation sequence by hand using aftertouch, with a series of very short impulses while I play my chord.
Typically I would like each modulation step to be very short, like a very short jump on the filter value.
But instead the filter modulation is applied flat during the whole length of the step…
FYI my only bypass so far is to double the number of modulation steps to introduce “0” steps in between.
But that is definitely just a poor bypass versus having the ability to adjust each steps modulation gate time.
And I have to double the master clock frequency.
For example, instead of having the 6 following ladder filter offset values at 118 bpm
+12 +12 +12 +38 +12 +12
I have to type in the 12 following values at 238bpm:
+12 0 +12 0 +12 0 +38 0 +12 0 +12 0
That vaguely starts to sound like someone adding pressure 6 times over a held chord/pad…
But keeping the initial 6 steps modulation sequence and having the ability to adjust each step’s gate time would be so much better.
Don’t target the filter cutoff directly. Consider step-modulating the filter envelope instead.
You could sequence e.g. the decay time and envelope amount. (You can use any of the four envelopes).
