I’m struggeling to set it as a slave to my DAW (Logic Pro X). If I change the tempo in Logic I want the Sub 37 to follow.
Is there anyone who would like to explain how to do this. Think I’ve pushed every button soon on the display and I’ve set the midi sync settings in Logic aswell.
I sync mine (am a newbie too) by setting my master sometimes my Aira TR-8 or many times ableton just by pressing the sync button in the arpeggiator section and I have the sync option on in ableton preferences so maybe your daw has a similar thing to do. if i have a sequence in the sub37 i select my patch and put the arp on button on then latch then press a key with sync on it wont do anything yet. then i start my master and the sub 37 sould start, you can if you want the LFO’s in sync too press the sync buttons in mod 1 and mod 2.
