How to obtain Sub Phatty Editor release 1.0.3?
I want to use the Sub Phatty Editor VI Plugin in Sonar Platinum, but it won’t load.
It turns out this is a known issue (see below).
How do I obtain Release 1.0.3 of Sub Phatty Editor-VI(x64).dll ?
http://webcache.googleusercontent.com/search?q=cache:P7G_OFfMMi4J:forum.moogmusic.com/viewtopic.php%3Ff%3D20%26t%3D25814+&cd=1&hl=en&ct=clnk&gl=au
Sub Phatty Editor Release 1.0.3
Sub Phatty Editor-VI(x64).dll - Working in Sonar, but automation only works when SP set to Midi Channel 1
Sub Phatty Editor(x64).dll - Working in Sonar, but automation only works when SP set to Midi Channel 1
MIDI forwarding does not work - when ‘MIDI Out’ of the plugin is enabled in
Sonar, playing keys on SP do not appear to be received by Sonar.
Sub Phatty Editor-VI(x86).dll - Working in Sonar, but automation not supported (VST Bridge Limitation)
Sub Phatty Editor(x86) - Working in Sonar, but automation not supported (VST Bridge Limitation)
Sub Phatty Editor Release 1.1.0
Sub Phatty Editor-VI(x64).dll - Will not load in Sonar. The plugin manager tries to scan it, but something fails.
Sub Phatty Editor(x64).dll - Working in Sonar. Automation works whatever Midi Channel the SP is set to.
Sonar, playing keys on SP do not appeart to be received by Sonar.
Sub Phatty Editor-VI(x86).dll - Will not load in Sonar. The plugin manager tries to scan it, but something fails.
Sub Phatty Editor 1.0.3 and Firmware 2.0.1 (released in september 2013):
Hey, thanks so much! I’ve joined the beta group, and I am informed there is a new beta for the editor coming soon, hopefully that will work with Sonar.
Appreciate your help.
