lately i am getting a bit frustrated with my Voyager. It is a wonderfull Instrument, but since a couple of months the typical Moog sound is not matching in my music anymore. How can i make it NOT to sound like a vintage Minimoog? How can i get rid of that woody vintage string character? I want it to sound more buzzy fresh and up to date, especially with those attractive new analog synths around… Elektron A4, Arturia Minibrute, Analogue Solutions Telemark, Oberheim SEM v2…
What else is slumbering inside besides the 70’s Lead styled sounds…
EDIT Ok…i just browsed the forum and found some tips. Switching filter poles e.g. or use that feedback trick. I’ll do that.
I route my Prophet-600 thru the Voyager and control it with MIDI. That way the Voyager is kind of polyphonic. Mixing other sound sources with the Voyager oscillators may also lead to new and fresh sounds.
Use distortion, bitcrushing, Sample Rate reducing, digital clipping or overdrive your mixer’s preamp. Everything that distroys the sound will make it “modern”.
Thank you guys, some great tips. I run my Voygi sometimes through a Oto Biscuit, and i recently purchased a Make Noise Maths as well as some other Make Noise modules, to bend the V. sound.
To change the filter poles is btw. already very rewarding! The results are fantastic. Like discovering a new synth. Regarding another synth…i have a Vermona Perfourmer Mk 2 right next to the Moog. Maybe i should use that as a four stage filterbox for the V… hmmmm.
