Hi
I thinking of buying the Rack for my moogerfoogers… Im guessing that you have to remove the 4 screws that hold the rubber feet on to the backplate, and then just use the same 4 screws to attach the pedal to the plate without the rubber feet …
Can anyone confirm this for me…
Paul
yep, take off the 4 screws, then mount the fooger, line up the holes with the holes in the racking unit, then screw the rubber feet in.
the middle fooger unit if you have one will need both it’s wood endcaps unscrewed and removed as well.
