How to disable mod or pitch controls?
Is this possible? Manual says “MOD and PITCH strips are assignable in the MOD section and can be toggled On/Off in the SETUP page” but there is no screenshot to clarify that. Where is the “MOD section”? Where are these “On/Off” toggles?
Just to be clear, I wish to toggle them “off” but I don’t see such a toggle on the setup page.
Hi intrasight,
The Mod section is actually named the “ENV/MOD” panel, third on top.
To show or hide the strips, the toggle feature you’re referring to, that’s done from SETUP, then select Configuration on the left, and then top-right you’ll see the button to display or hide the strips.
Hope this helps :slight_smile: Alex / Satri
Thanks. Yes, that will show and hide. But I wish to disable. I’m using a MIDI controller (LinnStrument) and the MOD control still works even when hidden. If it can’t be disabled, can the sensitivity be adjusted?
Not sure that can be done on Animoog’s end, however, can’t you disable sending those MIDI CCs on the LinnStrument’s side? Another potential option, maybe changing the MOD MIDI CC mapping on Animoog’s side will do it? Good luck – Alex
