Did you use the Minitaur VST on the same track with an external instrument? Or do you use two tracks, one for midi and one for audio??
I use only one midi track with an external instrument and the Minitaur VST as an fx… It is working perfectly and it is more simple… BUT the only problem is that the preset and knobs position in the VST editor are not following the program change I can do in different midi clips of Ableton…
It is possible to live with that but if someone have a trick to make it working, I want it!!! ![]()
So thanks for sharing your set up in Ableton!
