I know this is elementary stuff. Ive tried using the “set end” button but no luck.
i have 2 32 step sequences I’m trying to get the Mother 32 to play back to back. I know this has to be possible without nudging the pattern from 1 to 2 every time you want it to move on to the 2nd 32 step sequence. Right?
Hey. Can you explain that to me? Im not MIDI savvy in the least.
To give everyone an idea of all I’m trying to do…all it is is a 64 step sequence for two different parts on 2 M32s. All 8th notes. Very simple. Below is a simplified lead sheet…
M32 1 Part 1: 4/4 ||:CCCCCCCC etc|Cx8|Ax8|Ax8|Fx8|Fx8|Fx8|Fx8:||
M32 2 Part 2: 4/4 ||:GEGECEEC:|| x8 measures
Since I found out I can’t have the Mother32 play a 64 pattern as is required for “Part 1” (this according to the Moog guy that wrote me back…if he’s wrong, PLEASE PLEASE let me know!!! That would be GREAT!) Ive been trying instead to figure out how to play “Part 1” as ratcheted 8th notes (so basically still 32 steps and ratcheted) so that it is only still four 8 step patterns (=32 steps).
I would have thought that then I could use Setup Mode to change the “Tempo Input Mode” for Part 1 (to Assignable Output Mode 3: Sequencer Clock/2) so that Part 2 is still playing in the intended tempo and Part 1 would basically be feeling “half time” by taking the Assign Patch out of M32/2 into the Tempo Patch of M32/1? No?
Well it doesn’t work. Not at all.
I have faith that what Im trying to do MUST be possible. Kind of crazy that something so simple isn’t easier to figure out.
