How Do The 14bit Midi CCs Work?
I’m writing some software to control my Sub37 from a real (and virtual) modular system.
I have control via standard midi cc working fine, also control via 14bit midi nrpn as specified in the manual working fine.
I can’t get the ‘normal’ 14bit CCs to work though. Can someone tell me exactly what I should be sending to get these to work? I’ve tried the same method I use for nrpn only with 101 and 100 for the msb and lsb respectively, also tried sending as two separate control messages with values for the msb and lsb but neither of these methods seem to work.
thanks in advance!
Don’t worry, figured it out. LSB has to be sent first which I guess makes sense really!
