Is there any way to set the value amount that cutoff responds to aftertouch ? and if not, how can I switch it off ? Quite annoying with my Ableton Push controller, as I like to have it sensitive, but when using with the Sub Phatty it adds modulation when I need a straight bass sound at times.
I also would like to know how to fix this problem. This is interrupting my workflow and changing the way my sub phatty sounds and it usually sounds quite nice. Please help.
Are you sure? Have you checked? Doesn’t the Sub Phatty Editor software just send MIDI CC when pushing its buttons? I thought anything the software editor can do any other MIDI controller should be able to do as well.
The setting is hidden in the prefs sub screen, not in the main GUI.
Anyway, checked what happens when changing the setting, it is a sysex stream:
F0 04 06 23 18 00 xx 00 F7 with xx from 0 to 127, default 32 i guess.
As far as checking I’ve got my Sub Phatty Manual and it doesn’t mention it in there, I thought maybe someone would know more here, which you guys do but I’d don’t feel up to the challenge of learning about Sysex…sorry. maybe the info will become available if it does exist. Thanks
