voyager midi lights responding to midi messages from sequencer/external controller, but it never actually activates any sound. i can lean over and play the unit and make sound, but the midi messages are not translating inside the unit. the channels are all set and, like i say, it is seeing events, but nothing.
is there something dumb in the menus i am missing? i perused but didn’t see anything that looked relevant.
it would be just terrific to be able to use the midi functions of this guy…
In OS 3.2, check MASTER menu 2.2, 2.3 & 2.4 to make sure that the correct MIDI channels are selected, and MIDI IN & OUT are ON (they probably are, but check anyway).
Then check MASTER menu 4.2 and make sure that the MIDI Key Order Parameter is set to “is not active”.
You might find the Voyager OS 3.2 Menu Reference helpful for current troubleshooting and future reference. This is a chart that lists all of the PANEL, EDIT and MASTER menu commands and selection options. You’ll find it in the 'Voyager Essentials" folder (in the Files section) on the SquareWave site:
