HELP
Hi
I accidently bought one of these theremin upgrades.
http://www.thomann.de/fi/moog_etherwave_plus_field_upgrade.htm
I thought it was full theremin because there are picture of build theremin.
Instead I get bunch of electronics. I added pictures.
http://img443.imageshack.us/gal.php?g=picture004b.jpg
Can I still build full functionable theremin out of these parts I have
(1) 11-213 PCB assembly
(3) 15mm nylon hex nuts
(1) Etherwave Plus Front Panel
(1) 5-wire harness
(2) 50K linear taper potentiometers (labeled 50KB) w/ hardware: lockwasher, washer, and nut.
(2) 5K linear taper potentiometers (labeled 5KB) w/ hardware: lockwasher, washer, and nut.
(1) 50K audio taper potentiometer (labeled 50KA) w/ hardware: lockwasher, washer, and nut.
(1) #6 Locking terminal
(1) LED
(1) LED spacer
(2) 1/4” TRS Jack assemblies w/ hardware: lockwasher, washer, and nut.
(1) power switch
(1) knob
(1) calibration tool
here’s a guide
http://www.moogmusic.com/manuals/e_plus_field_upgrade_man.pdf
I know I’m missing antennas and power source.
no
You bought the upgrade kit. In addition to the antennas and power supply, you are also missing the case, the circuit board, and everything else that is required to have a functional theremin. Try contacting your dealer to see if you exchange it or get a refund.
