I have midi parts recorded into pro tools that I am trying to send to the phatty but for the life of me cannot get the audio back to pro tools. Can somebody walk me through the correct midi settings in the phatty and the correct daw channel I/O’s?
If you plug in headpohnes in you Phatty, does it play?
(=notes are recieved)
If so, the problem is the audio back to you computer.
If not, start with the midi issue.
I don’t know how Pro Tools works, but this is obviously a daw-question and not a midi- or phatty-question.
Maybe someone else here knows PT or if you can find a PT-forum somewhere.
Are you saying you only hear the phatty when the track is armed for recording? If so I think this is normal (depending on your interface, direct monitoring…). I use Sonar, and I can hear audio without the track armed, but I get no meters until I arm for recording.
Good luck!
-e
