i recently started building up my eurorack and i purchased a flame clockwork.. for starters i don’t have any euro vco’s and i am getting by using the little phattys vco, vcf, and vca.
my problem seems to be with the gate.. the clockwork puts out a cv, clock, and gate. But when i try to put the gate to the key gate on the LP i just get an always open gate(or maybe closed.. ooops cant remember).. either way the only signal that actually triggers and retriggers the gate is the cv.. but sadly i would rather route that differently and it doesn’t go well with my patching.
does the moog gate trigger abnormally? i am not really sure whats going on here. you would figure that gate should goto gate
also my understanding of teh lp is that when i put a cv sequencer into pitch cv in… the LP adds the SEQ CV to the last note played CV on the phatty… is there a setting to turn that off?
if i set my last note played on teh phatty to the lowest note in the lowest octave does that set my phatty up to recieve the correct voltages/notes (other than the fact that the lp is set up outside of 1volt/octave?)
i am running a tip top z8000, clockwork, qmmg, and maths
i might not be expaining the best but please try and help
