help with ableton!!
Hello guys,
i just bought the LP stage 2 but im having trouble understanding how to use it with live (connections, routing, settings in the preferences etc..) i have the m-audio fast track pro as my audio interface. can someone help me out, thnx
What aspect are you havin a problem with?
I also use a fasttrack pro and ableton.. it should be straight forward.. I just run a 1/4 inch jack from the headphone output to line 1 or 2 of the fastrack.. in preferences just make sure your audio in is set to the fasttrack pro.. not much to say after that!
what if i want to use 2 different sounds out of the LP in a track, do i have to convert to .wav or can I do some routing like doing with the Virus TI??
If you are recording the LP on a MIDI track and you want more than one track then yes, you need to record it as AUDIO instead.
Ableton has a great manual and their online help talks alot about how to make the best of the various capabilities, etc.
I don’t get it.. if you want 2 sounds on the LP, it’s monophonic/non-timbral so you would have to record 2 different audio tracks.
Why would you run from your headphone output instead of audio out?
cause right now I only have 1/4 cables haha.
Interesting. My LP’s Audio out jack is 1/4 inch…am I missing something here? :confused:
