Help: sub37 editor appears only as an fx insert...
here is my config.
Windows 7 ultimate X64, cubase 8.5,.
I followed all the steps mentionned in the install process…Usb drivers, new firmware and so on…
In cubase…the editor only appears as an insert fx. In the plugin manager…the sub37 editor isn’t showing off Under instrument row.
Anybody encountered such a thing?
It loads an an effect in Ableton, so this sounds like the same thing:
http://forum.moogmusic.com/viewtopic.php?f=7&t=24258&start=60#p149266
it makes sense that it works like this to me, as it allows for the DAWs latency management for external instruments vs the handling of VST instruments that generate their own audio, which the editor clearly doesn’t.
Same here
Hi.
Sub 37 Editor is not supposed to appear as VSTi in Cubase, only as an effect insert, so you are well.
Gil.
Strange, I replied to this topic as soon I found the “problem”. but I can’t see it. Anyway, all is fine, I was used to the subphatty editor so much than I previousely thought it was a failure…Everything is ok now.
