help! no sound on phatty!!!
i set up my phatty stage ii, to control my virus ti desktop, via midi. ive since unhooked the ti, and i have no output noise on the phatty whatsoever! when i turn it on or off, i can hear my speakers pop.. but when i press a key, i hear nothing! this happens with both, the output, and the headphone jack. plz help!!
What are your MIDI SETUP settings? Have you tried various settings in the MASTER menus?
…could be the local control has been turned off… check under the MIDI master menu… or, if you had hooked up both MIDI IN and MIDI OUT to the Virus, maybe a MIDI volume message of 000 was sent from the Virus…
the other possibility is to make sure the output button on the LP is on… obvious, I know, but not always the first place you’d look when tracking down a seemingly complicated answer… good luck, jgirv
That would make sense except no audio comes through his headphones…but that was my first thought. :mrgreen:
yeah the output button is on… i made sure to check that. anyway, i appreciate all of these fast replies, you guys are awesome… ill have to check it later though, because im at work right now. ill post back when i get home in about 3 hours..
MIDI SETUP:
local cntrl:on
midi in: none
midi out: none
MIDI MERGE:
usb in: none
din in: none
MIDI SETUP:
poly:16 of 16
all notes off <— there is no way for me to change this, from what i see
PROGRAM CHANGE
snd: off
rev: off
midi ch in:off
midi ch out:off
i should also mention that there is no usb or midi cable connected currently. please, for the love of GOD… if anyone can help!!! im worried this thing is FUCKED!!!
i had to turn the poly to off. phew!
Yeah, that threw me for a loop the first time I uploaded OS 2.00 to my Stage I…glad you figured it out! The forums are always here in case you need future help! :mrgreen:
…that’s just a panic button if MIDI notes are sticking… it’s been on most synths for years… you probably won’t ever need it, unless you hold a note and unplug the MIDI cable while ya hold it…
Glad you got everything straightened out! – jgirv
