Help me.
I bought a VX 351 CV Expander for my Voyager AE and after installing it my X/Y/ expression pad in the center does not function any longer? Has anyone else had this problem??? Does anyone have any suggestions?
Sunsinger ![]()
Help me.
Sunsinger ![]()
No, not at all - mine work very well together. It was actually a big part of the reason why I got the vx351 - I use the XY pad to control other gear.
Is the vx351 connected to your voyager or not? If not, is the db25 cable connected to the voyager but not the vx351? If it is, have you tried remocing the cable? Have you tried switching presets? Turning the voyager on and off? Have you checked that the daughterboard inside the voyager is seated properly? Have you tried removing the daughterboard altogether (i.e. returning to a pre-installation state)?
Hopefully, one or other of those questions may resolve the issue…
