Calling Amos at Moog tomorrow morning, but I thought Id ask here. My LPF 101 is acting weird. It won’t pass a dry signal through it while bypassed. It only makes sound while engaged. also the level light stopped working. Any ideas???
… the input amp is buggered?
Hope it’s up and running soon.
just tried calling you, Shakti… if you have no Drive LED and no sound when bypassed, then you have a sick MF on your hands. At a guess, either the input amp has failed, or there is a problem with the output amp, which if a certain section failed and is shorting to ground would pull down the dry signal which also feeds the level LED. Either way it probably needs professional assistance.
I can look at it here, or if it’s out of warranty I’d be happy to provide help to the repair tech of your choice.
Amos
