Help connecting Moog guitar to an etherwave plus
Hello all
Finally my moog guitar and my etherwave theremin plus are under the same roof. But I can’t seem to find out how to connect them together. I have connected the Pitch CV on the etherwave to the CV input on the moog foot pedal, and then from the audio out on the foot pedal to the amplifier. Is this correct? Is it some special edjustment I have to do on the guitar or the etherwave?
Help will be MUCH appreciated! :slight_smile:
That certainly sounds correct. I haven’t tried using the CV input on my Moog E1, but the CV input should control whatever the foot pedal is controlling. I believe the CV input is mixed with the foot pedal and the corresponding control on the guitar, so make sure one of those controls isn’t zeroing out the input from your etherwave plus.
Thanks for the answer! :slight_smile:
The funny thing is that the Volume CV on the theremin works perfectly, maybe you have to have both of them connected for the Pitch CV to work? and how would you do that since there is only 1 CV input on the foot pedal? :confused: I hope nothing is wrong with the theremin…
