Do you experience a noise from the headphone output?
It starts to be slightly noticeable at the 9 o‘clock position of the headphone volume pot . When I turn the low cut to the right the noise is gone.
No noise from the L/R stereo output.
My Muse arrived last week and apart of known bugs it works well (no tuning issues).
My headphone output has no noise but it depends on which headphones you are using maybe? I’m using high impedance headphones so maybe that’s pushing the noise floor lower. But ya i don’t notice noise at all. Is the noise significantly different from the main outputs?
Also how hard are you driving it, because the overload will also push up the noise floor.
I am using the Roland Aira M100 with low impendance of 32 ohm. The loundness at 15% is pretty good. I start to notice the noise between 15-20%. I checked the headphones on my sub37 and subsequent37 - no noise.
It’s from the frame cutting into the ribbon cable and grounding out. There was a video and I fixed mine also. I’m looking for it. Never mind that was my PA5x but could be a similar issue.
