does moog offer this or do i have find another source. also do you fine tone loss with the moogers?
no tone loss only tone gain!
ah yes of course! what moogers do you have goldie?
I wouldn’t true-bypass my 'foogers. I kinda like the idea of a warm, analogue preamp adding a bit of flavour to my bass/guitar/rhodes/synth. You would probably have a bit of trouble matching the levels also.
It’s nice overdrive too: just plug a hot signal in and turn up the drive knob!
I think too many guitarists make too much out of “true bypass.” Perhaps if you were using all digital processors with cheap components and a poor design, that might mean something. All that matters is whether your audio sounds good or not.
well theres alot of fuss about t-pass because alot of pedals do suck treble.
but yeah my mooger phaser plays tricks on me sometimes. it sounds beautiful some days, not other days. maybe its just me.
i have the sd delay, the phaser and the lpf. they all have a really goey sound which i love. theres too muc treble in modern music anyway and these boxes can preserve that or get rid, which is what i prefer.
I haven’t modified my Moog pedals, as I pretty much use them in the studio only. If they’re plugged in, they’re on. If I were to use them on a guitar pedal board, I would probably get one of those tue bypass loop pedals instead of modifying the pedal.
Bryan
I think that’s what I’d probably do too, but I also tend to use them for recording only.
I have to agree with most of the other people that have posted that the Moogerfooger preamp is great, even with the effect bypassed.
I must say, though, that I’ve noticed with the MF-101 low-pass filter, when used with bass, there’s a slight volume drop if the mix is set all the way over to effect. It’s not that bad, but enough to make me wish there was an output level control like on the MF-103 and -104. Anyone else notice this?
There is a definite volume drop, but it really just takes some fine tuning when you’re recording. I would never think of using a by pass, but I only use them for recording as well.
I think they make for nice pre amps, too. I have the 101, 102, 103 and 104 and my voyager goes through them before going into a tube pre. There’s probably a slight loss of top end, but that’s basically the essence of analog, isn’t it? You listen to any of the classic recordings from the 70’s and they sound so musical because the top end is so tucked in as compared to nowadays where it dominates the mix.
i have my ring mod and lowpass running thru a tb unit, because they add a noticeable hiss that i dont like. the phaser i dont tb, because it sounds fine.
if you like the sound that the bypassed moogs make, then dont tb them…
The 101 manual says that the drive knob is always on even when the pedal is bypassed. The easy way around that is to simply turn it all the way down. That doesn’t work with the 105 though I don’t think.
For that matter, true-bypass is a bit over-rated and the fooger’s click-free on/off is preferable to a guy like me that runs an eleven-pedal-board.
I use to run an MF-101, MF-103 and MF-104 on my pedalboard but now I’m down to use the MF-104. If I go back to using the MF-101 I think it’ll be with a true bypass looper for one reason only, because I like to have my distortion or fuzz pedal before the 101 and I think the fuzz is slamming the 101 in bypass and I can’t get the fuzz to cut through. If I turn up the fuzz it just slams the 101 harder and doesn’t get any louder.
haven’t noticed this problem while only using the MF-104.
yes, i used the lehle d.loop to true bypass my LPF. the lehle is a wonderful product, and if you really want to use your moogerfoogers without that bypass crap going thru your signal, it is in your interest to invest in a looper. you seriously can’t go wrong with a lehle.
i kid you not, it felt so good when i true bypassed my LPF for the first time. absolutely brilliant.
I have used the mf-101, 102, 103, and 104Z on my pedalboard for quite some time and I’d have to say the opposite of what many have said here…they boost my signal sgnificantly. I also use some fuzz pedals before any of the moogerfoogers and have had no problems at all with the sound cutting through. I’ve got an analogman sun face fuzz which inherently has trouble boosting the signal but I goot say it works great with the moogerfoogers and also I use a lovetone big cheese a lot and it also ssounds great and very LOUD through the moogerfoogers. One thing I will say is that it definately takes some time to set up all the moogerfoogers and their respective drive controls so that they are not overloading too bad…although A little overloading sounds awesome, especially with guitar. The MF-104z is probably the worst out of any of them…it overloads really quickly although that might just be because it’s the last pedal in my signal change. My advice is to spend some time really gettting all the drive controls worked out on your moogerfoogers so that they are all vibing together…when you do, trust me, yoiu wont want them true bypassed!
I use the Radial Big Shot EFX true bypass fx loop switch to bypass my MF-101.
This way the pedal has 3 modes - bypass; tone / volume boost; filter. When I play heavy thick distortion, the pedal kinda over does things when the red light is on, but I can bypass it to keep the sound going into the distortion less “powerful” which prevents muddiness, and keeps the distortion clean and direct (if you know what I mean).
It’s absolutely awesome for warming up the clean tones, and mildly driven sound. Even after a chain of tone robbing pedals, it really can make up for them, but in more of a cover-up way than replacing the sound that is subtracted.
I’ve noticed it had good and bad days too!!
