Grandmother sequencer retrig/reinitiate sequence or not?
Hi everyone! New here.
I have a question about the Grandmother.
Situation: sequencer running in hold.
If you press a key to transpose the sequence, does this only transpose letting the sequence continue (please make it so), or it also restart the sequence from the first step?
Thank you!!
Andrea
Anyone? :bulb:
I just tested mine, it restarts the seq from the beginning when you press a key
however, this may be adjustable: have you read the manual?
edit I just had a look through, and it doesn’t appear to be adjustable in the global settings
Thank you Ummagumma!
I also contacted the Moog technical support and it seems that for now the behaviour I desire is far from be implemented. Anyway, I solved in two ways:
  • use the sequencer of a Keystep
  • sending a toggle sustain pedal midi message (cc64) while GM seq is in PLAY mode only (no hold)
