I’ve been losing my mind trying to figure out what is happening here. Basically I have 2 Dfams, 2 Mothers, and a Grandmother all going into my Apogee Ensemble into Logic. For some reason I can’t figure out, the Grandmother is VERY quiet in the mix. Even with the mixer showing that the signal coming in from the GM is normal (and looks like it should be actually very loud).
I’ve tried everything I can think of. Switching inputs in to the Ensemble, different cables, using the same cables I had routed to all the Dfams and Mothers, and still I get the same results. The Grandmother just seems quieter than everything else.
I even plugged the GM into my QSC K10 to make sure the signal isn’t coming out very quiet and just about blew the speaker on the K10. It’s not the output on the GM. PLENTY loud coming out into a powered monitor.
I’m at a loss. I’m sure it’s something very stupid but I’m giving up. I even tried a TRS cable just to make sure the Apogee wants that for some reason. No dice.
Any similar issues?
