Grandmother MIDI Implementation
Hello,
I’m having problems with CC: 103 (Gated Glide), 107 (Pitchbend Up), 108 (Pitchbend Down) and 119 (Keyboard Transpose). Can it be that Grandmother does not react to these commands? V 1.0.2 is my OS version.
Meanwhile I tried it with USB MIDI, same behavior, or better misbehavior.
Maybe someone is able and willing to try it out on his GM?
No answer from Moog in the meantime, I suppose they are all building Matriarchs.
I think, the MIDI Implementation Chart for the GM is not correct.
I just made a test with those four parameters and CC 103 Gated Glide worked as expected. The other three didn’t
Thanks for your kind support.
I tried it once more, you are right, GATED GLIDE works, my mistake. But the other three are really out of work.
Can anyone confirm if all CCs work on firmware 1.0.6? I don’t have my Grandmother around these days
