I’ve been looking for such a topic without any success. I hope I’ve done the right search and apologize otherwise.
I don’t own any GrandMother but some local users had some ideas I thought it would be interesting to suggest to MoogMusic and to share here. If some og you guys have good ideas to share, feel free to do so.
First off, I think that any hardware upgrade is hard to hope for. I think firmware evolutions through –say- global settings are more akin to happen. Planning to send a mail to MoogMusic some day…
One press transposition.
One of the most wanted feature (to accommodate with the short keyboard) is the possibility to transpose without any button combination. Hence some users stated they would prefer having the transposition management through single press and the sequencer/arpeggiator management through the combinations. They imagined a way to select one or the other configuration on a global setting basis.
They also imagined that a double click on the hold button would toggle on or off the hold function.
Gate retrig.
Another often mentioned wish is to be able to select the retrig mode: either legato or retrig. I think this can be implemented just as on the Voyager Old School, but I’m not sure.
I agree with the single button push options, for transposing
would be nice to be able to use the NOISE as a modulation source, and modulate it too? it appears you can only blend it in at the mixer?
( although I suppose you could take audio from WAVE OUT for each OSC, and solely use the NOISE at the mixer…but then you are sacrificing the whole mixer for just noise )
I don’t know how but keyboard velocity, since it does have it, should be routable to amplitude. I know that isn’t a vintage synth thing but still keyboard velocity is there in the synth already and it’s good to be able to use that nuance of musicality.
I’ve see videos on YouTube where the use the S/H at a high freq as a noise modulator.
I’d also love to see a duo mode capability. That’s one of my favorite things about my Sub 37 because you can create some beautifully fat 2 note harmonies!
I desperately want the arpeggiator to have more direction options; I hate that up/down repeats the first and last note and would pay money to change it to an exclusive up/down
