Hi. Is there any way to set Grandmothers Arpeggiator to auto-align its notes timing to downbeats of external MIDI Clock?
I use the synth extensively with my Roland MC-909 groovebox, which is a midi master sequencer and clock master for the whole live setup, and the problem is in ARP start time in GM.
I have to press PLAY (ARP ON) button exactly in time with downbeat, which is not always possible in live situation.
For now I use a workaround for it:
- press GM’s PLAY to turn ARP on
- stop the groovebox and restart its pattern from 1st bar
- GM’s ARP will now play in sync
But it’s no good for me and for audience )
When I replace GM to Sub 37 and use its ARP, there is no such problem - it’s always in sync with midi clock, even if I press a key in wrong time. The same with Nord Stage - always in sync.
I wonder if there is a hidden system setting for this behavior in Grandmother or maybe will in next firmware?
