GM Midi Sync with ProTools Problems
When I used Protools to try to record a sequence through the internal sync and the usb cable, the sequence would not play, but would only repeat a single note. What gives?
Hey.
Might be a midi loop
Okay - Thanks. Look into that.
Hello,
I’m having the same issue with Ableton. Did you manage to solve this ?
Not at present. Too much trouble so I went back to Logic.
