Hello, I’m a new Voyager owner. Is there a way to globally change the keyboard mode rather than having to edit it for each patch?
It seems most of the patches that came with the OS 3.5 update are set to the “lower” keyboard mode (which I don’t even understand why you would want to use lower or upper modes) but I want ALL of the patches to go by the last note played. Any way to do this for all patches without having to go through each one’s edit menu and changing it manually?
The “lower” mode (actually named low note priority) was the way the original Minimoogs and many other, including non-Moog synths behaved. If you are used to it, you have problems in adjusting your playing style to the last note priority.
Many famous solos of Minimoog artist only work on a low note priority keyboard. And after all, the Voyager is meant to be a a Minimoog after all. So it uses its original keyboard mode more then the non old Minimoogs one. I think this was well done by Moog. Rather think of the other modes as new additional features. And don’t think the low note priority is “wrong” or unusable.
