glide mode 2 does not work as I expect
I thought that overlapping midi notes would create glide, and if there is a gap between notes, there would be no glide.
I actually dont get this to work with Live. Please help
You thought right, that is correct.
I’m not a Live user but It works the same with every sequencer I have tried, so I’m not so sure live is the problem.
On the Voyager is your" glide rate " set to a mid/high value and is your " trigger mode " set to single trigger ?
thanks man, Its glide mode 4 that works like this, although glide 2 should work like this from what i read in the manual…
All the Legato modes should work like that. If only mode 4 is working , then I dont know what could be wrong.
Glide mode 2 does work here fine since its introduction.
I guess its your setup (Midi loop?) or the sequencer is overlapping notes.
