I’m sure I’ve probably just overlooked something . . . but how do I get glide to work in both directions on the keyboard while holding down keys?
While programming from the “init params” starting point, I’m only able to map glide while going from a higher held key to a pressed lower key. Is there a way to make this work both ways?
Hopefully, I’m being clear–and not asking too bonehead of a question!
It sounds like you need to change your note priority. Enter the Edit menu for each patch, go to “Keyboard Modes” and select Last Key. You may also want to experiment with the Trigger Modes to change the attack.
