GilW the automation is now working for me
Hi Gilw,
Not really shore why its working now but I tried to use the editor with just the windows driver, so I had deleted the moog driver, but couldn’t get that way to work.
But when I had re installed the moog driver its seems to some how of fixed the problem and now is all work great :slight_smile:
MESA
I’m not sure I understand,
Are you referring to the 4th automation lane in Ableton ?
Can you now automate any number of parameters and there’s no problem ?
Did you only reinstall the moog USB driver ?
I don’t understand why it was working but today its not :frowning:
as I said yesterday I was going to try it without the midi driver and use the windows driver and a midi cable (like the miniature setup) but this way had the same problem,
I’ve been talking to Salvator about the problem and he wanted me to show him the problem over teamviewer
So I installed the driver again and connected with Salvator on teamviewer, loaded up ableton to show him,
But it just worked and we couldn’t get it to grey out, and I had around 7 lines of automation running. It’s always the way when you try to show somebody the problem it dosent happen.
It work great all night, but now I have opened ableton the same project that I used to show Salvator, and its just greying on the automation lines again.
Salvator did send me a email late last night and said
he’s been able to reproduce the issue of greying automation, and there working on something.
Hopefully a fix will come soon.
sorry so, No its not working right still
MESA
OK, thanks very much for your assistance to Salvator. There’s actually a fix for it ready but we may need to embed it into the first update after the release of 1.0.0 as it involves too many changes which need careful attention. I may send you a non official beta just to verify it indeed solves your issue.
Just to clarify - in any case are you still able to automate 3 parameters without any issues, correct ?
It’s critical to assure that before we release.
Thanks again !
Yes I can without any issues, automate 3 parameters.
Great to know you have a fix and yes let me know when you have the non official beta ill give it a good test :slight_smile:
