Ghost in my machine
My Voyager has starting doing something odd.The external audio volume knob,when turned,switches the patch on the display (does not actually change to that sound though). If I switch the on/off switch 4 the external in the mixer,it will revert back to its intended function.
Anyone else have this issue? Any idea whats up?
In the OS 3.4 Addendum you can find the following :
Changing Presets
When Quick Mode is ON, you can now change the presets using the External Audio Level pot without having to press the ENTER button.
And you can also turn that external audio knob feature on and off, only scrolling through presets with the cursor button.
The presets won’t change if you turn the external audio switch on…if theres no sound coming in it won’t do anything. Its only really an issue when you are running something in the audio, you have to turn that off to switch thru a lot of presets.
WHether or not they change when you hit enter is a second option.
