Hi Gang,
Had a pair of really cool shows this weekend using 4 'foogers that were drivin by the CV Outs of my Etherwave Plus.
I used Noise from the CP-251 to feed my MF-101 Low Pass. I used the CP-251’s S&H into the Lag processor to create a realistic automated wind. The S&H was blended in the CP’s Mixer along with the Theremin’s Pitch CV so that I could have
a believable wind that could be dramatically biased with a wave of my hand.
The Theremin’s Volume CV also went to the CP where I needed to use 2(!) of the Attenuators (with negative values) to get
the voltage to be positive and strong enough to modulate the Resonance of the LowPass. It also increased the Rate and Resonance of my MF-103 Phaser so that it whistled and bubbled as I waved my left hand.
This was used for both “Wish you Were Here” and “One Of These Days”, both of which feature extreme wind effects.
Then, on “Welcome To The Machine”, I kicked in the MuRF to create tempo-locked machine steam noises with the same
setup. This all fed a TimeBender that was also tempo locked, but at a different beat unit. Each echo had a different Pitch
Shift so that every steam pulse had rhythmic contrapuntal panning responses.
75 more pics can be found at: http://picasaweb.google.com/TRENDPLANET/PINKDROYDLIFEBRIDGE2010#
Dueling Trombones - Biding My Time
