Firmware update and presets
I’m about to update my Sub 37 from v1.1.0 to v1.2.0 In order to use the sound editor. I can’t find any information as to whether the presets I’ve created will be overwritten when updating the firmware? Do you know if my presets will still be there if I make the update?
Regards
Gustav
Make it a good habit, and do a full backup of your sounds before you update. Even if the update is not deleting the sounds, something might go wrong at a bad timing, like a power failure while updating.
Backing up can never hurt, but if all goes according to plan your presets should just still be there after the firmware update.
