Hi, all!
Now the proud owner of Sub Phatty #302.
I was having some of the similar issues discussed in previous threads and updated the firmware, now, if I attempt to use the synth with Ableton, local off or otherwise, it becomes totally unresponsive after about 10 minutes. It was tracking midi fine, controls were acting normal, then out of nowhere, not a single knob (including master volume) works.
It just drones on and goes out of tune until I reboot.
Also, the octave +/- buttons don’t work if I use the active panel setting (all i use). If I go back to a preset, and hold the active panel button and press the octave buttons a few times, sometimes it will shift octaves after I switch back to active panel. It is also routinely shifting back to Filter EG as modulation source, regardless of knob position or preset.
One instance of the second oscillator having to be turned to -3 to get it anywhere near in tune with Osc1 and the Sub Osc.
Local control also has to be reset to “off” every time I reboot, could be normal, just haven’t encountered that on any of my other machines.
Any ableton users having similar problems?
If I leave usb unconnected, it will behave properly in some instances, but, usually after about a half an hour, something goes wonky…
Heck of a first post, yeah?
Cheers!
