filter release knob is affecting pitch
First of all hello to all of you.
I’m a new moog owner and this is my first post here. From my first days spent with the voyager I can see that I’ll stick around for some time. this is by far the best synth tone I’ve ever played.
However, I’m having some problems with some patches in which the filter release knob is affecting the overall tune of the synth. It looks just like the fine tune knob, but it’ds the filter release.
You guys know what may be causing this?
This can happen when you go to the 2.5 software package without following all the steps. See if that fixes it.
From the OS 2.1 instructions:
Step 11 – Factory Setup Menu
If you’re updating from Version 1.5 , you’re not done yet!
Version 2.1 has many new features – presets created in older versions of Voyager
software may behave strangely until the new features are initialized, because they may
have random values stored in memory for the new functions. Any time you import a
bank of presets created from an older version of Voyager Software, you will need to go
through this Initialization procedure. Go to Master Mode and select “4.4 Copyright Info”
and press ENTER. Press the +1 button to enter the “Factory Setup Menu”
Step 12 – Initialize Envelope Gates
Select the function “2.3 Env. Gates F/A” and press ENTER. The Screen will prompt:
“Reset the Env Gates Filter/Amplitude for all Preset Sounds? Yes/No” Select Yes and
press ENTER.
Step 13 – Initialize Pot Mapping
Select the function “Pot Mapping” and press ENTER. The screen will prompt: “Reset
the Pot Mapping function of all Preset Sounds? Yes/No”. Select Yes and Press ENTER.
Step 14 - Initialize Clock Divider
This function can be skipped if you are upgrading from Version 1.5, which already
contains the Clock Divider function. Definitely skip this if your presets have your own
stored values! If you are upgrading from an earlier version of software. Select the
function “Clock Divider” and press ENTER. The screen will prompt: “Reset the Clock
Divider Values of all Preset Sounds? Yes/No” Select Yes and press ENTER.
Step 15 – Initialize Shaping 1&2
Select the function “Shaping 1&2” and press ENTER. The screen will prompt: “Reset
Shaping 1&2 Functions of all Preset Sounds? Yes/No”. Select Yes and press ENTER.
Step 16 - Initialize Touch Surface Destinations
contains the Touch Surface Destination function – though the Touch Surface Gate
Destination was not previously implemented. In this case, you may have to go in and
change the Touch Surface Gate Destination to your liking. Definitely skip step 17 if your
presets have your own stored values other than the defaults (cutoff,spacing,
resonance)! If you are upgrading from an earlier version of software Select the function
“T.S. XYAG Dest.” and press ENTER. The screen will prompt: “Reset the Touch Surface XYA
& Gate Setup of all Preset Sounds? Yes/No”. Select Yes and press ENTER. Press CURSOR
to get back to the Master Mode menu.
This completes the installation of version 2.1 and the initialization of the new features
in your Voyager.
Thanks! That solved the problem.
