Has anyone out there done the filter glide mod on their Voyager themselves and if so would you care to share how?
Talk to MC.
I wouldn’t mind knowing this, either. I’d rather not ship the Voyager half way around the world… Not sure if there are any registered techs here.
I didn’t do the mod myself, Moog Music did it for me.
Even if I knew what the mod was, I couldn’t share it because of warranty issues. Sorry…
I can’t find any information on the filter glide mod on the moog website. when did this come out? what does it do, and how can I tell if my voyager has it?
thanks
Chris
The filter of a non modified Voyager is not tracking the keyboard with the glide circuit function. That means, that a long glide whil sweep the frequency of the oscillators but the keyboard tracking of the filter is without the glide.
To check this, use full keyboard tracking on a self oscillating (max emphasis/Resonance) LP filter. No Envelope or other modulation on the filter. Then use plenty of glide. Des the filter changes its frequency in instant steps when playing big intervals? If yes, there is no filter glide.
The filter glide is something the Minimoog had. And this is why so many people think they miss it on the Voyager. But actually many of them do not use it at all, or do not know how to find out if its there or not.
I don’t miss it at all. And I discovered the Minimoog got filter glide only after I read about the Voyager did not have it. So, it isn’t something as serious as the after touch mod.
Before my Voyager arrived I was worried about the aftertouch and filter glide but it’s such a great sounding instrument that I don’t really miss either of them. They can wait…
thanks till.
not totally sure i followed you, but it does seem like it’s something of little consequence. i think the part i don’t follow is the instant step frequency changes. i’m not sure i’d be able to recognize them if i heard them. the voyager can often be a very humbling instrument.
You will notice very easy if the pitch of the self oscillating filter jumps from one pitch to another, or if it takes a sec or more if glide is present.
I think you don’t need to be trained or skilled to get the sonic difference on the first try ever.
I’ll be ordering a Voyager Select soon from an online retailer and I’ll be disappointed if it arrives without filter glide. That is a very cool feature. I first became acquainted with it when I owned a PolyMoog. Using filter glide I got the BEST rhythmic wha wha effects. Better than I could get with any other modulation or filter envelop techniques. I have a couple of questions for those of you who have the mod. First… You can have filter glide ON with OSC pitch glide OFF, right? I’m assuming the answer is yes, but I figured I’d ask anyway. Second… How can my online retail rep be sure he’s sending me a unit with that mod? Will the software version number be a reliable indication? Is filter glide a hidden function, or is there actually a hardware switch or knob setting that’s clearly labeled?
I recently picked up a used voyager and it looks like a very early model.
(its got the white pitch/mod wheels and the name plate in the centre of the keyboard)
anyways, ive tested the hell out of it and its pretty solid but i do know it needs the 3.x upgrade, the aftertouch mod, and the filter glide mod.
Now i’m a DIY’er so i like to do as much stuff myself if possible especially if its out of warranty hardware.
Also, shipping it to moog is a major hassle and involves international shipping and even worse dealing with USA customs ![]()
Now the 3.x upgrade and aftertouch mod aren’t a problem because they are available from moog as a proper field kit. Its the filter glide mod i cant seem to get any specific info on.
I figure if i can handle building a paia 9700 i can probably handle clipping a resistor and wiring it somewhere as long as there is no SMT involved. If there is, i have resources to get that done locally.
Anyways, enjoying the hell out of the voyager so far. (this makes #4 in my moog family so far)
If someone has any specific details/documentation/schematics for performing this mod, please PM me.
In theory: yes
But this is not the way this mod is normally done. The aim of this modification is to make the Voyager act like the minimoog. And there was only a single glide circuit on the minimoog.
Sure, with some electric knowledge, this is possible to add.
And the analog board is not SMT. At least not on units I saw opened yet.
OK, then let me ask the question a little differently. As designed, does the filter glide mod for the Voyager allow you to route the control voltage of that single glide circuit to the VCF without also routing it to the VCO? I would hope there are 3 routing options; To the filter, to the osc, or to both.
I don’t think so.
Because this would need additional switch and this would not be stored with the patch. Therefore adding these three possible glide option would be a very special modification.
My guess is (I am not a tech):
right now the keyboard voltage is sent to the VCOs and the VCFs on separate ways before the glide is added. The glide circuit is only in the CV path to the VCOs.
After the “official” mod, the glide circuit is acting first on ALL keyboard CV and then the voltage is send to the VCOs and VCFs on different paths.
So the “official” mod is maybe nothing more than cutting a trace and soldering a jumper cable.
It is Moog Music decision to publish the mod or not.
My Voyager is off the warranty.
And I opened it for some pictures and for the memory upgrade before.
OK till. Thanks for your input.
I’d probably prefer to have one of the hardware engineers at my day-job company make the mod for me if it ever gets published.
My Voyager is very-much out of warranty.
