Just took the gamble and updated Filtatron. Can’t get landscape to work, any thoughts?
Thanks in advance!
Thanks in advance!
It’s not just you. Won’t switch to landscape for me on iPad 4 and iOS 8.
Same here -
no landscape mode on iPad 2, iOS 8+.
Last version of Filtatron “sort of” worked ~
It wouldn’t automatically startup in landscape mode (a PITA if using a docking station like the iO Dock), but a quick tilt of the iPad would change the orientation.
Bummer…
i emailed Moog support about this so hopefully we will get an official response. I’ll post if I hear back.
Update … There is a support ticket opened with Moog so they are aware of the problem. No additional info at this time.
Just installed the Filtatron 1.4.0 update and landscape is still not working. It’s not listed as one of the fixes so I suppose they didn’t bother to address the issue. In fact, if I rotate the iPad 180 degrees the screen starts to flip around but settles in oriented upside down. Now when I have the iPad docked I have a choice, use Filtatron upside down or sideways.
I also installed and actually was so invested in the new routing possibilities with audiobus that i overlooked this issue ![]()
Anyway it runs very smoothly so far!
But yeah if you could fix landscape mode, i’d be very grateful..
Ditto -
Latest Filtatron & iOS updates, still no landscape mode.
Dang - at this point I would much rather have the landscape mode fixed than any additional audiobus functionality… ![]()
Landscape mode now appears to be working correctly in the latest Filtatron update -
so far, I’m not seeing any issues with the latest iOS & Filtatron running on an iPad 2.
Cool!
Thank you Moog!! ![]()
Yes, I’ve installed the update and it works!
ipad2 ios7.something
Thanks!!!
