MarkM
1
I thought I would start a thread since there is no forum for the app.
I have an iPod Touch 4th generation. The only issues I have found are:
- When the pads’ active points are on the lower right hand corner, they get stuck. I have also had it happen when they are on the far right.
- Can’t read lower text on “Transfer Files” because it is gray on a black field.
ipod touch 3rd Gen.
“Save As” does not work.
Freezes up.
I cannot excape from the save as area.
MarkM
3
I have a similar problem with the Save New. I go to save and a loud buzz occurs which won’t go away unless I hit another preset.
iPod Touch 4.
Volume has been my only issue on the iPhone 4 but is only an issue when using the speaker, on headphones you get the full blast!
