Anyone else having similar issues? I made a loop in beatmaker and then copied & pasted to filtatron, but when I select said sample the app crashes. Tried different samples, reinstalling, etc., the loop is only a few seconds long and less than 2 MB.
have you found a fix for this. i am having same exact problem. its odd because manual specifically says filtatron uses intua pasteboard. i am using an ipad 2.
I have the same problem on an iPhone 4. Copying a two bar loop from beatmaker to filtatron works fine, but as soon as I open it the app crashes. Quite a downer as this is what I purchased it for…
