What’s new
• Supports iOS 7.1 and 8.x
• iPhone 4s/5/5s/6/6 Plus and iPad Air 1/2 compatible
• Audiobus for total integration with your other audio apps! Filtatron can act as a source, a destination, or a filter for audio from other compatible apps
• Basic Inter-App Audio Effect support
• HTTP and WebDAV support for file transfer
• Bug fixes and stability improvements
My Apogee Jam (first version) is not working anymore with the latest filtatron app 1.4.0 ;(
It seems that the input device is not recognized by filtatron. (Jams LED remains blue - which means powered but not active[green led] )
When using Audiobus then I can feed the input from my apogee jam into the filtatron app. Strange.
… and landscape mode STILL doesn’t work on iPad 2 with latest iOS updates…
Found the solution - It took me a while but its easy:
- Open your “iOS Settings”
- scroll down to your installed Apps and select Filtatron
- “Audio Input” - change to desired input.
In my case: USB where the apogee jam is connected via the USB camera connection cable.
Seems to me that this is new to 1.4.0 - In previous versions my audio interface was recognized automatically. but however it works now.
@Moog: thanks for the update!
