Odyssey Mk1 lead
Osc: Wave Oct Freq
Osc 1 4 (097) 4’ n/a
Osc 2 4 (093) 4’ 0 (-4)
Osc3 0 8’ 0
Mixer: Volume Off/On
Osc 1 9.2 (249) On
Osc 2 4.8 (119) On
Osc 3 0 Off
Ext In 5.8 On
Noise 5 Off
Filter: Freq: 155Hz (84), Spacing: +.5 (+30), Res: 5.5 (143),
KB Cont Amt: 5.8 (155), Mode: HP/LP, Slope: -12db/-12/db,
Env Amt: +2 (+66).
Filter Env: Attack: 30mS (092), Decay: 7.5 sec (243), Sustain: 10,
Release: 40mS (119).
Amplitude env:: Attack: 10mS (47), Decay: 9.5 sec (254),
Sustain 10, Release: 45mS (143), Env gate: KB.
LFO: Rate: 5.5Hz, LFO Sync: Off/Sync
Mod Wheel Bus: Src: Tri, Dest: Osc 2, Shaping: On/Pgm,
Amt: 1.3 (013).
Pedal Bus: Src: Tri, Dest: Pitch, Shaping: On/Pgm, Amt: 0.
Glide: OFF, Glide Rate: 4 (097), Release: ON, Pitch Bend Amt: +/-
Major Third, 1-2 Sync: Off, 3-1 FM: Off, 3KB Cont: On, 3 Freq: HI,
KB Trigger: Multiple, Key Mode: Last Key Priority, Master Vol.: 3.8 (082).
Pot Mapping:
Pot Map 1: Src: Filter Res, Dest: Ext Audio In, Direction: Normal,
Amt: 50%.
Output Config: Stereo (can use mono but spacing cont needs to be
adjusted), Mixer feedback loop.
Note: Resonance control is mapped to ext in. Be careful. If the
‘ext in’ pot in the mixer is set to around 5.8, the mixer overload led
should begin to flicker when the resonance is set to 6 or so. This additional
feedback loop when used with pot mapping will closely simulate the
resonant behavior of the Mk1’s 4023. The filter mode will slice a bit off
the bottom, giving the sound the ‘mouthy’ character.
When the mod wheel is forward, there should barely be any beating between
Osc 1 & 2. When forward, it should introduce a hint of chorusy detune.
Pedal bus set for global vibrato.
Patch doesn’t need any effects, other than a bit of reverb.
Will leave a sysex copy on the Squarewave site.
Regards,
Lawrence
