Does anyone know of a method to quickly recall patches? I have a show this weekend, and have 8-9 different patch changes. This wouldn’t be too big a deal, but I have effects and another poly synth to dial up as well. Is there a way to copy all the patches I’m using to say the last bank?
Set the Vger to the patch you want.
Select save in the menu
Select the location you want to save it to
Then do the same for the name.
You can set patch changes in sequence and just hit the arrow or use a MIDI device to select them. (I use a Roland FC-200 for that)
If you set al the patches to the same locations in your machines, one foot tap can set them all at once.
