Hi everyone, I am trying to use a Source Audio Hot Hand as an expression source for my MF-107, but I have found that the Hot Hand’s sweep range is diminished significantly when using it with the MF-107. I suspect this is due to mismatched pot values. Therefore, I need to mod one or the other so that I have an effective sweep range with the Hot Hand. Since I know neither the pot values of the Hot Hand or the Moogerfooger, I guess finding those would be a start.
That would be a good start, yes. If you don’t find the values online I could measure the resistance of my EP-2 later today.
Thanks. According to Moog, the Moogerfoogers are designed to work with the EP-1 and I’m not sure if it has the same pot values as the EP-2.
I do believe the moogs are 100K ohms now.
