not that i have comment on the quality, but i’m into a discussion on the gearslutz forumsite, about the envelops used in the t3 and the minitaur.
are they analogue or digital ?
thanks beforehand for the answer
Digital envelopes
thanks, topic can be closed
The other night I used my T3 for the first time in ages. Knowing now that the envelopes are digital, it gave me pause as I plugged it into my Monster Cable power strip with specially filtered outputs - should I plug it into the analog filtered plug or the digital filtered?
I use a Belkin powerstrip with no problems. All my gear is plugged into it. I’ve discovered through friends that there’s nothing “special” about Monster Cable products.
Pick an outlet and use it. I’m sure it will be fine.
Yeah, you’re probably right - I never bought into the whole Monster Cable thing - I will not use their cables - but when faced with the dilemma of which variety of plug to use it can cause some consternation. Of course, I forget once I start playing! ![]()
And the best part is - I’M USING MY TAURUS AGAIN! ![]()
